    Quelle: https://www.woltlab.com/pluginstore/file/7195-pdf-embed/
    • WoltLab Suite 5.4.16
    • WoltLab Suite 5.3.22
    How to Apply Updates
    Open your Administration Control Panel and navigate to "Configuration > Packages > List Packages". Please click on the button "Search for Updates" located in the right corner above the package list.
    • Deleting a blog containing articles now requires that you have the permission to delete articles. 5.4
    • The permission to create articles is now correctly considered for user groups as co-authors. 5.4
    • Menu items that link directly to a private forum now correctly show the number of unread topics. 5.4
    • Editing pictures of different members at the same time no longer causes an error message. 5.4
    • IP.Board 3.4.x
      • Gallery import was fixed. 5.4
      • Compatibility with MySQL 8 was fixed. 5.4
    • vBulletin 3.x/4.x
      • Forum sections are no longer imported incorrectly as categories. 5.4
    • Incorrect redirection for links to inaccessible articles. 5.4
    • When updating users, cover photos using the GIF format were not processed correctly. 5.4
    • The alignment of embedded file attachments was not displayed correctly in some cases. 5.4
    • Keyboard commands were interpreted incorrectly in nested dialogs. 5.4
    • Very small file attachments were displayed distorted in the preview. 5.4
    • Several improvements were made to the preprocessing of search terms for MySQL-based searches. 5.4
    • The external guzzlehttp/psr7 library was updated to correct a bug in HTTP header validation. 5.4 5.3
    • Updated favico.js to prevent an error when used with Firefox 100. 5.4
    • The cache is now reset correctly after creating new language variables via the administration interface. 5.4
    • A display error with empty code boxes has been corrected. 5.4
    • For developers: The PHP-DDL-API now rejects ->defaultValue() values for BLOB and TEXT columns, because they are not supported in older MySQL versions and only inconsistently between MySQL and MariaDB in newer versions. Additionally this pull request should be considered: https://github.com/WoltLab/WCF/pull/4733 5.4
    Quelle: https://www.woltlab.com/community/thre…-5-4-16-5-3-22/
    • Die Löschung eines Blogs mit Artikeln ist jetzt nur noch möglich, wenn man die Berechtigung zum Löschen von Artikeln hat. 5.4
    • Die Berechtigung zum Erstellen von Artikeln wird jetzt auch für Benutzergruppen als Co-Autor korrekt berücksichtigt. 5.4
    • Menüpunkte die direkt auf ein privates Forum verweisen zeigen jetzt korrekt die Anzahl der ungelesenen Themen. 5.4
    • Das gleichzeitige Bearbeiten von Bildern unterschiedlicher Mitglieder führt nicht mehr zu einer Fehlermeldung. 5.4
    • IP.Board 3.4.x
      • Der Galerie-Import wurde korrigiert. 5.4
      • Die Kompatibilität mit MySQL 8 wurde korrigiert. 5.4
    • vBulletin 3.x/4.x
      • Forenbereiche werden nicht mehr fehlerhaft als Kategorien importiert. 5.4
    • Fehlerhafte Umleitung bei Links zu unzugänglichen Artikeln. 5.4
    • Bei der Aktualisierung von Benutzern wurden Titelbilder im GIF-Format nicht korrekt verarbeitet. 5.4
    • Die Ausrichtung von eingebetteten Dateianhängen wurde in einigen Fällen nicht richtig dargestellt. 5.4
    • Bei verschachtelten Dialogen wurden Tastatur-Befehle fehlerhaft interpretiert. 5.4
    • Sehr kleine Dateianhänge wurden in der Vorschau verzerrt dargestellt. 5.4
    • Es wurden mehrere Verbesserungen an der Vorverarbeitung von Suchbegriffen für die MySQL-basierte Suche vorgenommen. 5.4
    • Die externe guzzlehttp/psr7-Bibliothek wurde aktualisiert, um einen Fehler bei der Validierung von HTTP-Headern zu korrigieren. 5.4 5.3
    • Anpassung von favico.js zur Vermeidung eines Fehler beim Einsatz unter Firefox 100. 5.4
    • Der Cache wird jetzt nach dem Anlegen neuer Sprachvariablen über die Administrationsoberfläche korrekt zurückgesetzt. 5.4
    • Ein Darstellungsfehler bei leeren Code-Boxen wurde korrigiert. 5.4
    • Für Entwickler: Die PHP-DDL-API lehnt ->defaultValue()-Werte für BLOB und TEXT-Spalten jetzt ab, da diese in älteren MySQL-Versionen nicht und in neueren Versionen nur inkonsistent zwischen MySQL und MariaDB unterstützt werden. Ergänzend sollte auch dieser Pull Request beachtet werden: https://github.com/WoltLab/WCF/pull/4733 5.4
    Quelle: https://www.woltlab.com/pluginstore/fi…google-one-tap/
    Quelle: https://www.woltlab.com/pluginstore/fi…e-verarbeitung/
    Quelle: https://www.woltlab.com/pluginstore/fi…aft-erinnerung/
    Quelle: https://www.woltlab.com/community/thre…-5-2-20-3-1-28/
    Quelle: Discord User online
    Quelle: https://www.woltlab.com/pluginstore/fi…asters-tsunami/
    Auf Grund eines Fehlers im Update von der Version 7.2.x wurde unabsichtlich das Rechnungsnummernsystem umgestellt. Das hat zur Folge, dass die erste Rechnung, die in der Version 8.0 ausgestellt wird, wieder mit R22-000001 beginnt. Das hat neben Auswirkungen auf die Buchhaltung auch Auswirkungen auf die Funktionsweise vom Shop, da es u.U. vorkommen kann, dass Rechnungsnummern doppelt verwendet werden. Dies wird zwar vom Shop aktiv verhindert, führt aber dazu, dass keine neuen Rechnungen ausgestellt werden. Von diesem Fehler sind nur Kunden betroffen, die von Version 7.2 aktualisiert haben und die Standardeinstellung zur Generierung von Rechnungsnummern verwendet. Dieses Plugin ermöglicht es betroffenen Kunden ermöglicht die fehlerhaft ausgestellten Rechnungen zu korrigieren.
    Das Plugin erkennt automatisch, ob die Installation von dem Fehler betroffen ist. Fehlerhaft ausgestellte Rechnungen werden vor der Korrektur aufgelistet und müssen aktiv bestätigt werden. Bitte überprüfen Sie unbedingt, ob die aufgelisteten Bestellungen betroffen sind und keine betroffene Rechnung fehlt. Anschließend kann die Korrektur durchgeführt werden. Dieser Schritt kann nur ein einziges mal durchgeführt werden und kann nicht rückgängig gemacht werden. Nach der Konvertierung kann der Betreiber entsprechende Stornorechnungen herunterladen. Kunden werden nicht automatisch informiert. Nach der Konvertierung und dem Herunterladen der Stornorechnungen kann das Plugin wieder deinstalliert werden.
    Quelle: https://www.woltlab.com/pluginstore/fi…mmernkonverter/
    Quelle: https://www.woltlab.com/pluginstore/fi…bbcode-qr-code/
    Quelle: https://www.woltlab.com/pluginstore/fi…-free-acp-stil/
    Quelle: https://www.woltlab.com/pluginstore/file/7169-acp-stil/
    [quelle='wbbsupport.de/shop/product/34-teamspeak3-viewer/']Teamspeak Viewer[/quelle]
    Quelle: https://www.woltlab.com/pluginstore/fi…eisters-bitpay/
