Quelle: Artikel Kategorierechte kopieren
WoltLab Suite 5.4.12 / 5.3.18 / 5.2.18 / 3.1.26
The previous update included a change to the behavior of the |encodeJSON template modifier to mitigate a potential security issue. This caused the structured data (used for the Google search engine and others) to contain encoded characters. While not causing any security issues itself it did prevent search engines from correctly evaluating the structured data.
For Developers
The |json template modifier was implemented in the development version of WoltLab Suite 5.5 as a replacement for the |encodeJSON modifier that has several flaws. The decision was made to backport this change to WoltLab Suite 3.1 and newer in order to resolve the issue addressed in this update.
https://github.com/WoltLab/WCF/pull/4645
If you are working with JSON data, most notably ld+json content, we highly suggest that you review the changes in the following commit. Please take note that the removal of the quotes around the string is intentional, because |json internally relies on \json_encode().
https://github.com/WoltLab/WCF…44b20d0b4d58eca2bad80d9d3
- Structured data in templates was malformed. 3.1 5.2 5.3 5.4
- Structured data in templates was malformed. 5.3 5.4
- Structured data in templates was malformed. 5.2 5.3 5.4
- Introduced the |json template modifier as a replacement for |encodeJSON. 3.1 5.2 5.3 5.4
Quelle: https://www.woltlab.com/community/thre…-5-2-17-3-1-25/
- WoltLab Suite 5.4.11
- WoltLab Suite 5.3.17
- WoltLab Suite 5.2.17
- WoltLab Suite 3.1.25
Sicherheitshinweis
Wir haben einen Fehler entdeckt, bei dem ein bestimmtes Zeichen beim Einbetten von so genannten JSON-Strings im Template bei der Nutzung des |encodeJSON-Template-Modifier nicht korrekt maskiert wurden. Im Standardumfang war es lediglich möglich, dass bestimmte Nutzereingaben zu ungültigen strukturierten Daten für Suchmaschinen führten, ein Sicherheitsrisiko entstand dadurch nicht. Bei Erweiterungen und Apps von Dritten konnte es potentiell zur Ausführung von JavaScript kommen.
Darüber hinaus haben wir ein weiteres Problem beim Forum entdeckt, bei dem es in bestimmten Konstellationen von Berechtigungen möglich war, auf Themen zu antworten, die man nicht sehen konnte. Dies konnte beispielsweise in Verbindung mit privaten Themen dazu führen, dass Antworten in fremden Themen erzeugt werden konnten. Es war zu keinem Zeitpunkt möglich auf diese Weise auf andere Beiträge oder sonstige Inhalte aus dem Thema zuzugreifen.
Alle Installationen von WoltLab Cloud-Kunden wurden bereits aktualisiert.
- Bei der Auflistung von Kommentaren in Boxen wurde manchmal die falsche Übersetzung von Dateinamen angezeigt. 5.4
- (SICHERHEIT): Die Sichtbarkeit von Themen wird jetzt bei der Prüfung der Antwort-Berechtigung korrekt berücksichtigt. Antworten anderer Benutzer oder sonstige Inhalte aus den Themen waren zu keinem Zeitpunkt sichtbar. 5.4 5.3 5.2 3.1
- (SICHERHEIT): Die Maskierung von JSON-Strings mit dem |encodeJSON-Template-Modifier wurde korrigiert. Im Standardumfang war es lediglich möglich, dass bestimmte Nutzereingaben zu ungültigen strukturierten Daten für Suchmaschinen führten, ein Sicherheitsrisiko bestand nicht. Bei Erweiterungen und Apps von Dritten konnte es potentiell zur Ausführung von JavaScript kommen. 5.4 5.3 5.2 3.1
- Die Erstellung von Datenbanktabellen bei der Installation von Apps, die die PHP-basierte DDL-API nutzen, wurde korrigiert. 5.4 5.3
- Die Anzeige von optionalen Spalten bei der Filterung der Benutzerliste in der Administrationsoberfläche wurde korrigiert. 5.4
- Die Verlinkung von Tabs der zweiten Ebene, beispielsweise in der Benutzergruppenverwaltung, wurde korrigiert. 5.4
- Das Einfügen von Zeilenumbrüchen in Code-Blöcke wurde unter iOS korrigiert. 5.4
- Bei der Aktualisierung des Titelbilds im Profil wird die Existenz einer WebP-Variante jetzt korrekt zurückgesetzt. 5.4
- Der Aufruf einer existierenden CMS-Seite führt bei fehlenden Berechtigungen jetzt korrekt zu einer „Zugriff verweigert“ statt einer „Seite nicht gefunden“-Meldung. 5.4
- Beim Einfügen von HTML aus Microsoft Word wurden einige Formatierungen nicht korrekt übernommen. 5.4
- Das Einfügen von Elementen in eine sogenannte „ItemList“ wurde korrigiert. Dies betrifft beispielsweise die Eingabe von Tags. 5.4
- Die Darstellung des Avatars in Zitaten wurde in Signaturen korrigiert. 5.4
- Bei der Verwendung von WebP-Smileys werden die Dimensionen jetzt automatisch ermittelt. 5.4
- Beim Stilexport werden versteckte Dateien im Bilderordner nicht mehr mit exportiert. Die Korrektur im letzten Update war unvollständig. 5.4
- Der Versand von E-Mails über das SMTP-Verfahren gilt jetzt als offiziell als „Empfohlen“. Der Versand über das PHP-Verfahren ist aus technischen Gründen von diversen Einschränkungen betroffen. 5.4
- Bei der Ersetzung von Medien durch kleine Bilder, die keine Thumbnails erzeugen, werden existierende Thumbnails jetzt korrekt zurückgesetzt. 5.4
- Die PHP 8.1-Kompatibilität wurde verbessert. 5.4
Eingabe von Dateigrößen extern verlinkter Dateien in der Filebase
Quelle: https://www.woltlab.com/pluginstore/fi…r%C3%B6%C3%9Fe/
[Blockierte Grafik: https://www.woltlab.com/attachment/168007-beispiel-filebase-png/?thumbnail=1]Als Ergänzung zum beliebten Forum SEO Texte Plugin gibt es nun auch die SEO-Texte für Kategorien. Somit sind die SEO-Texte nun auch in CMS-Artikel, Filebase, Gallery, Calendar, Blog, Ticketsystem, Vorschläge und überall wo sonst noch Kategorien genutzt werden verfügbar.
Mit diesem Plug-In können Sie einfach und schnell SEO-Texte für Kategorien verfassen, um den Inhalt Ihrer Seite stark aufzuwerten und eine signifikante Steigerung des Google-Rankings zu erreichen.
Das Plugin für das Forum wurde im Artikel 10 wichtige SEO-Tipps für dein Forum offiziell von WoltLab empfohlen um das Google-Ranking zu verbessern. Die Erweiterung auf Kategorien hebt die On-Page-Optimierung auf ein neues Level!
Funktionen im Überblick
- Individueller SEO-Text für jede Kategorie einzeln einstellbar
- Oberhalb oder unterhalb der Inhalte anzeigbar
- Wahlweise als Text oder HTML frei editierbar
- Über die Box-Berechtigungen können die Texte optional nur für Gäste (Suchmaschinen) angezeigt werden
- Steigern Sie mit diesem Plugin Ihre Position in den Suchmaschinen
Kurzanleitung
- Box auf Kategorie-Seiten aktivieren
Inhalt ➞ Boxen ➞ SEO Text (Kategorie) ➞ Seiten > [x] Liste von ... aus bestimmter Kategorie
Tipp: Anstelle alle Kategorieseiten anzuwählen, kann auch einfach Box überall sichtbar angeklickt werden. Die Box wird automatisch nur dann angezeigt, wenn eine Kategorie verfügbar ist und ein SEO-Text hinterlegt wurde. - Text für Kategorie hinterlegen
- CMS-Artikel: Inhalt ➞ Artikel ➞ Kategorien
- Blog: Apps ➞ Blog ➞ Kategorien
- Calendar: Apps ➞ Kalender ➞ Kategorien
- Gallery: Apps ➞ Galerie ➞ Kategorien
- Filebase: Apps ➞ Filebase ➞ Kategorien
- Ticketsystem: Ticketsystem ➞ Tickets ➞ Kategorien
- Funktioniert automatisch auch für viele Endanwendungen von Drittanbietern!
Beispiel
Wir nutzen das Plugin natürlich auch auf unserer eigenen Seite. Ein gutes Beispiel ist die Store-Kategorie für WoltLab Designs.
[Blockierte Grafik: https://www.woltlab.com/attachment/168011-seotext-html-png/]
FAQ
1. Was genau ist der Sinn und Zweck dieses Plugins?
Dieses Plugin ermöglicht es auf Seiten, die vergleichsweise wenig wertvollen Inhalt bieten (Artikelliste, Dateiliste, Bilderliste...), den Inhalt zu erweitern und damit aufzuwerten. So findet Google einige interessante Inhalte zu den gewünschten Suchwörtern und bewertet die Seite deutlich besser. Auf TOP-Seiten wie notebooksbillier.de, testberichte.de, zalando.de und vielen weiteren Portalen, die mit TOP-Keywords auf Platz 1 bei Google sind, kann man dies bereits sehr gut erkennen. Diese Seiten haben einen SEO-Text im unteren Bereich der Seite platziert um die Keyword-Dichte zu erhöhen und den Content wertvoller zu machen. - genau das macht dieses Plug-In.
Kurz: Der Sinn dieses Plugins ist es, durch besseren Content, die Position in den Suchmaschinen zu verbessern.
2. Was unterscheidet das Plugin von der Beschreibung für Kategorien, die man schon per Standard hinzufügen kann?
Leider kann in der Kategoriebeschreibung kein besonders relevanter Text erstellt werden. Ein guter Text, der positive Auswirkungen auf das Ranking haben kann, hat in der Regeln 400 - 800 Wörter. Das ist natürlich viel zu viel um in den Listenansichten unter dem Kategorie-Titel angezeigt zu werden. Des Weiteren hat man mit diesem Plug-In die Möglichkeit den Text nach Belieben zu gestalten. Auch das würde bei der Kategoriebeschreibung zu Darstellungsfehlern führen (z.B. wenn man ein Bild einfügt). Weiterhin ist es natürlich für den Inhalt der Seite immer besser, wenn mehrere Teile der Website relevante Texte enthalten. Also eine gute Beschreibung ist genauso wichtig, wie gute Themennamen und ein darunter liegender Fachtext.(letzteren kann man mit diesem Plug-In erstellen)
3. Wie sieht ein guter SEO-Text aus?
Ein optimaler SEO-Text bietet als erstes immer auch einen Mehrwert für den User und muss sich natürlich lesen. Dabei ist der Text im Optimalfall zwischen 400 und 800 Wörter lang. Der Text sollte interne Verlinkungen zu themenrelevanten Seiten enthalten, so können zum Beispiel CMS-Artikel, Foren-Themen oder Filebase-Dateien verlinkt werden. Das gewünschte Keyword, sowie Synonyme davon, sollte einige Male (allerdings nicht zu oft) im Text enthalten sein. Analysiere am besten mit Googles Keyword-Planer, wonach am meisten, bezogen auf das Thema des Forums, gesucht wird und nutze diese Keywords gezielt in deinem SEO-Text.Empfohlen
WoltLab Cloud
Datei
WoltLab Suite Forum: SEO Texte
[Blockierte Grafik: https://www.woltlab.com/pluginstore/images/file/a8/2556.png]
Ermöglicht es suchmaschinen-freundliche Inhalte individuell für jedes Forum zu verfassen.
1. November 2021
Quelle: https://www.woltlab.com/pluginstore/fi…e-gallery-blog/
Produktinformationen
Viele mögen zwar den Originalen Stil von Woltlab doch hätten diesen auch gerne etwas farbiger oder würden der Community den Stil in mehr als nur einer Farbe anbieten können. Mit dem SimpleColor Pack ist dies kein Problem, einfach das komplette Pack über die Paketverwaltung installieren und schon kann der User zwischen verschiedenen Farben auswählen.
Mache deine Community etwas farbiger und lasse deine User entscheiden wie es denn gerade aussehen soll!
Verwandte Produkte
keine
Support
- Als Kunde erhalten Sie ausschliesslich Support in unserem Supportforum auf GrischaMedia.ch
- Wir bieten keinen E-Mail, Konversationen, TeamSpeak, Discord oder Telefon Support an!
- Support und korrespondenz wird ausschliesslich in der Sprache Deutsch geführt!
Häuffig gestellte Fragen
- Gibt es einen Installationsservice?
Ja nach der Registration kann so ein Service über unseren Shop gebucht werden. Installations-/Upgradeservice - Wie erhalte ich Support im Forum?
Nach dem erstellen eines kostenlosen Accounts, muss die Pluginstore Freischaltung bei uns durchgeführt werden.
Informationen
[Blockierte Grafik: https://www.woltlab.com/attachment/153703-grischamedia-banner-500x62-png/]
Quelle: https://www.woltlab.com/pluginstore/file/7121-simplecolor/
Das Userpanel befindet sich in der oberen Rechten Ecke und hat eine gewisse Transparenz damit das Header Bild nicht verschwindet. Alle Woltlab App`s wurden an den Stil angepasst und sind normal nutzbar.
Verwandte Produkte
keine
Support
Informationen
Quelle: https://www.woltlab.com/pluginstore/file/7119-swisscoffee/
Auf der suche nach einem dunklen angenehmen Stil der doch noch etwas fröhliches und farbiges mit sich bringt? Dann ist DarkMode genau das richtige Produkt für deine Community bzw. Woltlab Suite Webseite. Die Anpassungen wurden Grundsätzlich an mehrer App`s angepasst, voll funktionsfähig und getestet sind alle Woltlab Produkte wie es auch den Bilder in den Impressionen zu sehen ist.
Verwandte Produkte
keine
Support
Informationen
Quelle: https://www.woltlab.com/pluginstore/file/7117-darkmode/
Der Nachfolger des beliebten WBB4-Plugins, jetzt brandneu für die WoltLab Suite 5!
Das Plugin integriert die Giphy-Suche in dein Forum! Mach dein Forum bunter und erlaube einzelnen Benutzergruppen die einfache Suche nach GIFs über die Giphy-API. Die Suche kann überall dort genutzt werden, wo auch der Editor genutzt wird!
Funktioniert überall wo es Benutzerinhalte gibt (Forenbeiträge, Blogartikel, Kommentare und vieles mehr)
Benutzergruppen-Recht
Allgemeine Rechte -> Nachrichten -> Kann Giphy Suche nutzen
Einstellungen
Konfiguration -> Allgemein -> Giphy
Quelle: https://www.woltlab.com/pluginstore/fi…eine-community/
Dieses kleine Plugin (fast schon zu wenig für ein Plugin...) fügt einem Thema zusätzliche Informationen unterhalb des Themen-Titels hinzu.
Voraussetzung:
Mind. WoltLab Suite Forum 5.3.15. Das Plugin läuft auch unter WoltLab Suite 5.4.
Angezeigt wird eine Nachricht in der Form Es gibt 68 Antworten in diesem Thema welches 1713 mal aufgerufen wurde. Der letzte Beitrag (01. Januar 2022) ist von djblueprint..
Hat ein Thema noch keine Antwort(en), wird auch keine Nachricht angezeigt.
Dabei ist "letzte Beitrag" verlinkt mit dem letzten Post in dem Thema und der Autor des letzten Beitrages ist wie üblich verlinkt (inkl. hover).
Es gibt keine zusätzlichen Optionen. Einfach installieren und die Nachricht ist bei jedem Thread vorhanden. Der Text kann über eine Sprachvariable angepasst werden:
wbb.thread.de.3d-board.threadTopInfo (DE und EN sind enthalten).
Die Nachricht hat eigene CSS-Klasse (threadTopInfo) erhalten, so dass sie leicht an unterschiedliche Stile via CSS angepasst werden kann.
Um beispielsweise den Abstand zwischen dem Thread-Titel-Block und der ThreadTopInfo zu vergrößern, kann dieser CSS-Code verwendet werden:
Code
Quelle: https://www.woltlab.com/pluginstore/fi…hread-top-info/
Mit dem Kauf dieses Plugins, bist du berechtigt das Copyright des Plugins Gewinnspiel zu entfernen.
Voraussetzung
WoltLab Cloud
Datei
Gewinnspiel
[Blockierte Grafik: https://www.woltlab.com/pluginstore/images/file/05/3027.png]
Plugin um Gewinnspiel im Forum zu veranstalten.
12. Juli 2021
Support
Support gibt es im Supportforum oder im Discord für Käufer dieses Plugins.
Wie geht es nach dem Kauf weiter?
Quelle: https://www.woltlab.com/pluginstore/fi…-branding-free/
Mit diesem Plugin können Aktionen des Community Bots an Discord gesendet werden.
Screenshot
Voraussetzungen
Folgende Pakete sind Voraussetzungen:
- WoltLab Suite Core (Mindestversion 5.4.0)
- Community Bot oder Community Bot Cloud (Mindestversion 5.4.0 pl 1)
- Discord-API (Mindestversion 2.0.4)
Support
Support gibt es meinem Supportforum oder auf meinem Discord server.
Quelle: https://www.woltlab.com/pluginstore/fi…-community-bot/
Soziale Netzwerke stellen ein äußerst wertvolles Werkzeug dar, wenn es um das Promoten Ihrer Inhalte geht. Die WoltLab Suite bringt von Haus aus bereits die Möglichkeit mit, Inhalte auf diesen Netzwerken zu teilen:
Mit Hilfe der Erweiterung "Share To Any" wird diese Liste um eine Vielzahl zusätzlicher Möglichkeiten erweitert:
Amazon Wish List, AOL Mail, Balatarin, BibSonomy, Bitty Browser, Blogger, BlogMarks, Bookmarks.fr, Box.net, Buffer, Care2 News, CiteULike, Design Float, Diary.Ru, Digg, Diigo, Douban, Draugiem, DZone, Email, Evernote, Fark, Flipboard, Folkd, gab, Gettr, Gmail, Google Bookmarks, Google Classroom, Hacker News, Hatena, Instapaper, Kakao, Kik, Known, Line, LiveJournal, Mail.Ru, Mendeley, Meneame, MeWe, Mix, Mixi, MySpace, Netvouz, Odnoklassniki, Outlook.com, Papaly, Pinboard, Plurk, Pocket, PrintFriendly, Protopage Bookmarks, Push to Kindle, Pusha, Qzone, Rediff MyPage, Refind, Renren, Sina Weibo, SiteJot, Skype, Slashdot, SMS, StockTwits, Svejo, Symbaloo Bookmarks, Telegram, Threema, Trello, Tuenti, Tumblr, Twiddla, TypePad Post, Viadeo, Viber, VK, Wanelo, Wykop, Yahoo Mail, & Yoolink
Der Mehrwert dieser Erweiterung liegt klar auf der Hand: Auch die hierzulande weniger bekannten Netzwerke werden abgedeckt. Hier einige Beispiele:
In der Volksrepublik China sind soziale Netzwerke wie Facebook, Twitter und co. schon seit Jahren unzugänglich. Mit RenRen hat man dort ein beliebtes, soziales Netzwerk als Alternative geschaffen.
Ein weiteres Beispiel ist VKontakte, auch bekannt als VK. Dieses soziale Netzwerk gewinnt als Facebook-Ersatz in Russland immer mehr an Beliebtheit.
Um die Anzeige der Anbieter zum Teilen von Inhalten aber nicht mit rund 90 zusätzlichen Anbietern zu überfüllen, fügt diese Erweiterung lediglich einen zusätzlichen Button hinzu, welcher bei Klick ein Overlay öffnet, in dem Sie und Ihre Nutzer bequem aus diesen neuen Anbietern wählen können. Dabei werden die Anbieter, die über die Option "Anbieter zum Teilen von Inhalten" aktiviert sind, dort aus- und die deaktivierten Anbieter eingeblendet.
Erweiterbar
Über den zuvor genannten Funktionsumfang hinaus erhalten Sie als Administrator die Möglichkeit, sämtliche der mitgelieferten Anbieter bequem im Administrationsbereich Ihrer Community verwalten zu können. Dabei können Sie nicht nur bestehende Anbieter bearbeiten, deaktivieren oder löschen, sondern bei Bedarf auch weitere Anbieter hinzufügen. Durch unsere intuitiv gestaltete Verwaltungsoberfläche können Sie das Ergebnis sofort sehen und sogar direkt im Administrationsbereich testen.
Datenschutzkonform
Uns liegt der Schutz Ihrer Daten genau so am Herzen, wie Ihnen. Daher ist diese Erweiterung so konzipiert, dass sie zu keinem Zeitpunkt unaufgefordert Verbindungen zu den zusätzlichen Netzwerken oder Systemen herstellt. Eine Übertragung von Informationen (z.B. IP-Adresse und/oder Browser-Informationen) des Besuchers findet nur auf expliziten Wunsch (d.h. durch Klick auf einen dieser Buttons) statt.
Quelle: https://www.woltlab.com/pluginstore/file/7107-share-to-any/
[Blockierte Grafik: https://www.woltlab.com/attachment/167…pment-mini-png/] Einfachere Deinstallation
Suchen Sie mittels der Suche, in der Administration, nach einem Paket und deinstallieren Sie dieses direkt auf der Detailseite.
[Blockierte Grafik: https://www.woltlab.com/attachment/167786-web-1920-1-uninstallbutton-png/]
[Blockierte Grafik: https://www.woltlab.com/attachment/167…pment-mini-png/] Bugs & Support
- Ticketsupport: https://my.d1strict.net/support/
- E-Mail: development@d1strict.net
Paketbezeichner: de.d1strict.wsc.plugin.acp-package-uninstall
Quelle: https://www.woltlab.com/pluginstore/fi…lations-button/
Diese Plugin fügt ein mehrere Ranggrafiken System dem WSC5.4+ hinzu.
An dem an jeder Position per Javascript die Ranggrafiken eingefügt werden können.
Im Profil, Mitgliederliste, Seitenleiste,... und vielen weiteren
Wichtig!
Die Option "Benutzerränge" muss deaktiviert werden, wird mit der Installation automatisch gemacht.
Nach der Installation:
- Konfiguration der Ranggrafiken Benutzer->Benutzerränge die jeweiligen Bearbeiten und oder hinzufügen die man gerne haben möchte
- Zusätzlich als Upgrade oder Pflicht(Ranggrafik muss genutzt werden!) Ranggrafik verwenden
- Zusätzliche Positionen für das einfügen der Ranggrafiken hinzufügen, im ACP unter Benutzer->Ranggrafik Optionen->Ranggrafik Optionen auflisten, sofern gewünscht.
- Auswahl aus einer Liste von Positionen für die Ranggrafiken
- oder eigene Positionen definieren(Experten Modus)
- Im ACP unter Verwaltung->Wartung->Anzeigen aktualisieren den Button All mehrere Ranggrafiken aktivieren nutzen
- Um alle Ranggrafiken standardmäßig den Benutzern zuzuweisen
Folgendes kann das System:
- An jeder möglichkeit per Javascript und Ajax die Ranggrafiken einfügen.
- Ranggrafiken werden zwischen gespeichert in Javascript
- Die Anzahl der Ranggrafiken für einzelne Position begrenzen
- Benutzer können individuelle Benutzer Title setzen
- Dies kann nur genutzt werden, sofern die Ranggrafik nicht als Bild definiert wurde
- Benutzer benötigt zudem das Recht Kann eigenen Benutzertitel bearbeiten
- Ranggrafiken die immer genutzt werden müssen
- Sofern der/die Benutzer die notwendigen Bedingungen erfüllt haben.
- Alle Ranggrafiken den Benutzern zuweisen, über Anzeigen aktualisieren(Verwaltung->Wartung->Anzeigen aktualisieren)
- Ranggrafiken Upgraden
- Hierdurch können Ranggrafiken zu einer anderen Ranggrafik aufsteigen, sofern der Benutzer die notwendigen Punkte erreicht hat
- Die alte Ranggrafik wird nicht mehr angezeigt und die neue Ranggrafik wird nur noch angezeigt
- Individuelle Konfigurierbare Felder an denen die Ranggrafiken hinzugefügt werden können
- Standard vorgefertigte Positionen nutzen
- Oder selbst mittels Query Selektoren definieren wo dies passieren soll(Experten Modus)
Quelle: https://www.woltlab.com/pluginstore/fi…ranggrafiken-4/
Erweitert den Adventskalender um die Möglichkeit, Produkt-Gutscheine für den Viecode-Shop an registrierte Mitglieder verschenken zu können.
[Blockierte Grafik: https://www.woltlab.com/attachment/167480-advcal-jpeg/?thumbnail=1]
Quelle: https://www.woltlab.com/pluginstore/fi…hop-gutscheine/
Quelle: https://pluginstore.woltlab.com/file/7101-adve…hop-gutscheine/
- WoltLab Suite 5.4.10
- WoltLab Suite 5.3.16
How to Apply Updates
- When removing images from an album, the visibility is now correctly reset. Images that are not stored in an album do not support the specification of a visibility and are generally visible to everyone. The visibilities of affected images will be corrected as part of the update. 5.4
WoltLab Suite Core: Conversation
- Drafts are now counted towards the number of conversations sent only when they are actually sent, not when they are created. 5.4
WoltLab Suite Core: WebAuthn
- Updated the bundled external libraries. 5.4
- Several errors that could lead to invalid HTML when editing lists have been fixed. 5.4
- Reliability of inserting tables into the editor, e.g. from Google Sheets, was improved. 5.4
- Language switching for articles and activated developer tools does not work correctly. 5.4
- Missing permission to delete profile title images no longer causes a JavaScript error. 5.4
- In the user search the additional columns could not be deselected completely. 5.4
- Removing entries in the access rights setting could cause that changes were not saved. 5.4
- Zero-width spaces are now truncated at the beginning and end of entries. 5.4
- Selecting suggestions for search terms sometimes triggered erroneously. 5.4
- Text selection in the editor on mobile devices is no longer recognized as a "click" and now works as expected. 5.4
- Fixed a bug where the style logo was deleted in the database but not in the file system, leaving orphaned files in the file system. 5.4
- Supplied favicons are now correctly applied during style import. 5.4
- When exporting styles, hidden files in the image folder are no longer exported. 5.4
- Failed connections for Google Fonts download during style import no longer lead to an error message. 5.4
- Defective attributes of BBCodes could cause an abort during processing. 5.4
- For developers: The parameters of the include() family are now correctly displayed in the stack trace of error messages. 5.4
- For developers: An incorrect database state comparison for the length of a field in the PHP DDL API was fixed. In particular, YearDatabaseTableColumn was affected. 5.4 5.3
Quelle: https://www.woltlab.com/community/thre…-5-4-10-5-3-16/
- Bei dem Entfernen von Bildern aus einem Album wird die Sichtbarkeit jetzt korrekt zurückgesetzt. Bilder, die nicht in einem Album abgelegt sind unterstützen die Angabe einer Sichtbarkeit nicht und sind generell für jeden sichtbar. Die Sichtbarkeiten betroffener Bilder werden im Rahmen des Updates korrigiert. 5.4
- Entwürfe werden jetzt erst dann auf die Anzahl der versendeten Konversationen angerechnet, wenn diese tatsächlich versendet werden und nicht bereits bei Erstellung. 5.4
- Aktualisierung der mitgelieferten externen Bibliotheken. 5.4
- Mehrere Fehler die beim Editieren von Listen zu ungültigem HTML führen konnten wurden korrigiert. 5.4
- Die Zuverlässigkeit beim Einfügen von Tabellen in den Editor, etwa aus Google Sheets, wurde verbessert. 5.4
- Der Sprachwechsel bei Artikeln und aktivierten Entwickler-Werkzeugen funktioniert nicht korrekt. 5.4
- Eine fehlende Berechtigung zum Löschen von Profil-Titelbildern führt nicht mehr zu einem JavaScript-Fehler. 5.4
- Bei der Benutzersuche konnten die Zusatzspalten nicht vollständig abgewählt werden. 5.4
- Die Entfernung von Einträgen bei der Einstellung der Zugriffsrechte konnte dazu führen, dass Änderungen nicht gespeichert wurden. 5.4
- Nullbreite Leerzeichen werden jetzt am Anfang und Ende von Eingaben abgeschnitten. 5.4
- Die Auswahl von Vorschlägen für Suchbegriffen löste manchmal irrtümlich aus. 5.4
- Die Textauswahl im Editor auf mobilen Geräten wird nicht mehr als „Klick“ erkannt und funktioniert jetzt wie erwartet. 5.4
- Es wurde ein Fehler korrigiert, durch den das Stil-Logo in der Datenbank, aber nicht im Dateisystem gelöscht wurde und dadurch verwaiste Dateien im Dateisystem verblieben. 5.4
- Mitgelieferte Favicons werden jetzt beim Stilimport korrekt übernommen. 5.4
- Beim Stilexport werden versteckte Dateien im Bilderordner nicht mehr mit exportiert. 5.4
- Fehlgeschlagene Verbindungen für den Download von Google Fonts beim Stilimport führen nicht mehr zu einer Fehlermeldung. 5.4
- Defekte Attribute von BBCodes konnten einen Abbruch bei der Verarbeitung verursachen. 5.4
- Für Entwickler: Die Parameter der include()-Familie werden jetzt im Stack Trace von Fehlermeldungen korrekt angezeigt. 5.4
- Für Entwickler: Ein fehlerhafter Vergleich des Datenbankzustands für die Länge eines Feldes in der PHP DDL-API wurde korrigiert. Insbesondere war YearDatabaseTableColumn betroffen. 5.4 5.3
Quelle: https://community.woltlab.com/thread/293691-…-5-4-10-5-3-16/
